Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Formatting problem in Win XP
Forum Windows XP : Windows XP General Discussion - Formatting problem in Win XP
I have a system set up with two drives. A 3.1GB and a 14.5GB, both western digitals. I had Win98 installed on the 14.5GB drive. I then formatted the 3.1GB in FAT32 and installed WinXP on it. When i tried to format it, it got to 100% and an error came up saying "Windows was unable to complete the format". I then had to install WinXP by converting from Fat32 to NTFS rather than a full format.
I now have WinXP runing properly and want to format the 14.5GB drive and copy the entire 3.1GB drive over to it and run from the larger drive. When I try to format the 14.5GB drive I get the exact same error message. I even converted the drive to NTFS which worked fine and tried a quick format, but I still got the same error message.
Any advice on what may be causing this problem would be appreciated. I need to get the 14.5GB formatted since I'm out of space on the other drive.
Thanks,
Rob A.
Sponsored Links
There are 1510 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
