Hello. I am building my first computer and was looking for some advice. My budget is around €600. The computer doesn't need to be too powerful at the moment but I want to upgrade it in the future. Also I have decided to dual boot it with linux ubutu and windows 7. I have decided on the following:
Processor: Intel sandybridge i5 2500
CPU cooler: Intel boxed
Motherboard: Gigabyte ga-z68x-ud3h-b3
Ram: Haven't decided yet but I want 8gb preferably corsair whats compatible?
Graphics card: Don't think I'll buy one at this time, perhaps you can convince me to buy one!!
Case: Cooler Master Elite 310
PSU: Still undecided, I want something of good quaility at the right price.
Hard drive: Seagate barracuda 3.5 inch 500gb 7200rpm 16mb buffer
Optical drive: Samsung SH-222AB disk drive
Parts I don't need: Monitor, keyboard, mouse, speakers.
I think that thats everything. I am wondering if all of these parts are compatible and if they are all compatible with linux ubuntu.
Country: Ireland
Preferred shop: Online, as long as it is reputable and ships cheaply enough to Ireland.
Have I missed any neccessary parts? I was also wondering what voltage you think that this computer would need and how to work it out. Please respond soon, I can't wait to get started!!!
well... in Ireland it would need 240V to work if I recall correctly... I think you meant wattage though... with that build a 500 WATT would give you room to grow into a vid card for an upgrade easily...
no it will not be great for gaming... there are some games and it's getting better... I think ubuntu is a good "starter" linux but i would recommend (please distro zealots keep back) Debian. It's what ubuntu is based off of and is probably one of the most stable distros by default. It also has over 20000 packages in it's default repos so the chances of having a precompiled application for you to install is very high. Ubuntu is super easy to use but personally I hate the Unity desktop... If you've never used linux before you may love it as it seems people newer to linux love it... and a good 500w power supply will still allow for upgrades in the future... including a high end video card... your current equipment listed is only going to top out at like 250-300 watts leaving you plenty of room to grow with a 500w power supply... if you want to go higher I would recommend an antec earthwatts 650 but remember if you buy an earthwatts you have to buy the power cord separate because they intend for you to recycle your old power cord.
