Are the parts I have chosen compatible?
Last response: in Systems
December 22, 2011 6:29:27 PM
I'm building a PC and i have chosen these parts, but I don't know if they are compatible with each other. The main use for it is mostly gaming, though I will also use it for some video editing, though not much, most of it will be done at school, and typing up essays, Youtube, etc.
Case:COOLER MASTER HAF 912 RC-912-KKN1 Black SECC/ ABS Plastic ATX Mid Tower Computer Case
http://www.newegg.ca/Product/Product.aspx?Item=N82E1681...
CPU: Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor
CPU Cooler: COOLER MASTER RR-H612-20PK-R1 120mm Sleeve Hyper 612 PWM CPU Cooler
http://www.newegg.ca/Product/Product.aspx?Item=N82E1683...
GPU: HIS IceQ X Turbo H695QNT2G2M Radeon HD 6950 2GB 256-bit GDDR5 PCI Express 2.1 x16
Motherboard: ASRock Z68 Extreme3 Gen3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Hard Drive: Western Digital Caviar Blue WD10EALX 1TB 7200 RPM 32MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive
http://www.newegg.ca/Product/Product.aspx?Item=N82E1682...
DVD Drive: x2 ASUS 24X DVD Burner
PSU: CORSAIR Professional Series HX750 (CMPSU-750HX) 750W ATX12V 2.3 / EPS12V 2.91
Case Fans: 2 or 3 Scythe Kama Flow 2 120mm case fan 1400RPM
Thanks in advance.
