Hey guys,
So I've been having this issue ever since I update my hardware in my computer. The computer will go to sleep, sometimes wake up on it's own and never go back to sleep, or stay asleep and wont wake with key press. If I hit the power button at this point it flashes on for a second and then dies. I have to hit the switch on the PSU for about 5 seconds and then boot it up. From there the loading screen sometimes says "System Recovery" as if it lost power other times it gets stuck on a black screen with the letter cursor blinking in the top left corner. Hitting the power button quickly moves in onto the next bit. I am not sure exactly what is causing it, I read somewhere that it could be the PSU, but with my stuff recently changing I don't think it is. I have no real way to test it out because I updated from about six year old parts that wont work with the newer ones.
The parts in question are:
Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128510
Processor
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103962
Or RAM
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428
Here is the CPU, which is about a year or two old
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341018
Thank you!
Motherboard
Processor
Or RAM
Thank you!
