Ohhhh, slim case. Can you get a full size video card in the case? If not that explains the 9500GT.
If you keep the slim case look at a $90 Radeon HD 6670. Like this one in low profile:
http://www.newegg.com/Product/Product.aspx?Item=N82E168... or this one
http://www.newegg.com/Product/Product.aspx?Item=N82E168... If you look at the video card hierarchy chart
http://www.tomshardware.com/reviews/fastest-graphics-ca... you can see the 6670 is a lot higher up (three tiers below the 6770, eight tiers above the 9500GT.) It can game "Exceptional 1680x1050 performance in most games, 1920x1200 in most games with lowered detail" and will run great with the PSU in your slim system. A 6670 maxes at only 65 to 70 watts so heat in your case shouldn't be an issue. You'd need to make sure that the case will hold the card, maybe by comparing the length/height of the 9500gt card to the 6670 card.
Here are some benchmarks with SWTOR:
http://www.tomshardware.com/reviews/star-wars-gaming-te...
Looks like a 6670 would have no trouble with Low Detail, No AA at 1920x1080, and would struggle a bit at High Detail, No AA same resolution. HD5770 (and HD6770) would be OK at High Detail, No AA.
The same article on CPU says "When it comes to platform requirements, the game is much more forgiving. Really, any quad-core chip will suffice. Or, you could go with a dual-core processor running faster than 2.5 GHz." So your E6700 looks good to go.
re: "i could switch the case around. If i went with the HD5770 or HD 6700. What gsu do you recommend?" The hd5770 and Hd6770 are the same card renamed, both have TDP of roughly 105 watts. A good quality PSU of 350 watts would drive the video and an E6700 without effort. Maybe an antec earthwatts 380.
http://www.newegg.com/Product/Product.aspx?Item=N82E168... Maybe someone else can post a few suggestions. Get a larger PSU to at more money to give you more future flexibility.
How big is the PSU currently in the Dell case? A 250 watt PSU is no good. A 300 watt PSU has a chance of working (the E6700 peaks at 65 watts, the video at 105, the MB takes some too so reasonable max 12V would be 150 to 200 watts. A 300 watt PSU could put out 200 watts of 12V). A 350 watt PSU Dell original would work with the HD6700. -- One warning: A few of the older DELL Pentium II and Pentium III PSUs had a non standard power pinout in a standard connector. Very bad. The connector would fit in your MB, then fry it. Google the model Dell that came in the larger case if it was originally a PII or PIII and make sure the PSU in the case has a standard pinout.
ell_non-standard_power_connector" rel="nofollow" target="_blank">http://en.wikipedia.org/wiki/Template
![:D :D]()
ell_non-standard...
