Closed Solved
ATI Radeon 6950 3 display problem
So I am currently running the Radeon 6950. I doubt it matters for an issue like this, but at the end of this will be a link for my complete build.
Anyway I'm trying to set up 3 displays with my ATI card.
I have a 24" wide dell screen (Run through an ACTIVE minidisplayport --> DVI --> DVI)
a 28" widescreen I think (HG brand)[[ cable dvi--> HDMI(converter cable)]]
and a 43" widescreen HD vizio tv [[HDMI-->HDMI]]
I can get 2 displays at once with any combination of these 3 monitors. However I cannot get all 3 displays to work at once. I truly dont care to run 1 game through all these monitors, however I'd love to have a desktop that would span to the TV and I was under the impression with, 'the Active adaptor for the minidisplay--> DVI' , that would be easy. I cannot seem a way to do it. Could the DVI--> HDMI cable on the 28" be messing it all up? I dont see why because it will still display with either monitor, not both though.
Please if you have any suggestions or questions, I would love to solve this. Heres the link to my computer
http://www.costco.com/Browse/Product.aspx?Prodid=11622689&search=ibuypower&Mo=3&cm_re=1_en-_-Top_Left_Nav-_-Top_search&lang=en-US&Nr=P_CatalogName:BC&Sp=S&N=5000043&whse=BC&Dx=mode+matchallpartial&Ntk=Text_Search&Dr=P_CatalogName:BC&Ne=4000000&D=ibuypower&Ntt=ibuypower&No=3&Ntx=mode+matchallpartial&Nty=1&topnav=&s=1
8 answers Last reply Best Answer
More about radeon 6950 display problem
  1. Ye I think the 28" dvi-> hdmi, might be your problem. Are you sure your mindisplayport is active??
  2. Best answer
    I personally have had lots of troubles in the past, with Nvidia and AMD, when it comes to running multiple monitors with the use of HDMI. I can't even get two monitors to work if one is HDMI.
  3. well dual screens work fine... I will try with a DVI--> DVI cable tomorrow on the 28" screen and hopefully that will do the trick.
    And when u say the display port is active, you would be referring to the cable? I got an accell active minidisplayport-->DVI it says its ATI eyefinity certified up to 1950x1200 so I dont see the issue with that
  4. Ye i meant the adapter.
  5. http://www.amazon.com/gp/product/B004071ZXA/ref=oh_o02_s00_i00_details
    Here is the link to the adaptor I got. It is very much active.
    And to clarify once more. I dont really want eyefinity, I want 3 extended desktops.
    Any other ideas, or do you think I should drop another $200-250 on another HD6950. Kinda upset because half the reason I got this was to run a 3 display setup. But I'll do what I gotta do.
    The DVI-->DVI didn't help on the 28"
  6. Quote:
    This was exactly the problem it wouldn't run 3 displays with the HDMI port. =\
    Anyway got it going with the 28" going DVI-->DVI-->HDMI
    And Using the DVI--> HDMI cable for the TV..
    I wish I could get sound running thru the TV though.
    Another day another problem.
    Thanks everyone!
  7. Best answer selected by defn.
  8. This topic has been closed by Mousemonkey
Radeon DVI Graphics
