Difference between Z77 Extreme3 and Z77 Extreme6??
whats the difference between Z77 Extreme3 and Z77 Extreme6?
what makes the Z77 Extreme6 better? if i could save $50 then that'd be nice
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157330&Tpk=ASRock%20Z77%20Extreme3
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157295
my graphics card is a 7950 and cpu is i5-3570k
1 answer Last reply
More about difference extreme3 extreme6
  1. The extreme 3 has everything you need, the extreme 6 has more power phases, more sata ports, a firewire and display port connector and a better audio onboard(Realtek ALC898), i don't think it will be worth the 50$ extra for you.
    You can also look for the extreme 4, it has the same amount of power phases as the 6, it has the same audio onboard.
Motherboards Graphics Cards CPUs Intel i5 Product
