Compatibility Check Help
Hello, This is my first time building a computer and i would like to check if the parts are compatible.
Thanks in Advance
Approximate Purchase Date: 2 Months Time
Budget Range:£800-£1100
System Usage from Most to Least Important:Gaming, Animating
Parts Not Required: Monitor, Keyboard, Mouse
Preferred Website(s) for Parts: pcworld.co.uk , ebuyer.com , amazon.co.uk
Country: UK or US
Parts Preferences: by brand or type: ---
Overclocking: Yes
SLI or Crossfire: Yes
Monitor Resolution:1920x1200
Additional Comments: I would prefer it to be quiet
ASUS P8Z68-V Intel Z68 ATX Motherboard - LGA 1155 Socket
http://www.pcworld.co.uk/gbuk/asus-p8z68-v-intel-z68-atx-motherboard-lga-1155-socket-11160630-pdt.html
Intel Core i7 2600k 3.4Ghz Socket 1155 8MB Cache Retail Boxed Processor
http://www.ebuyer.com/252535-intel-core-i7-2600k-3-4ghz-socket-1155-8mb-cache-retail-boxed-processor-bx80623i72600k
Asus GTX 560Ti DirectCU II 1GB GDDR5 Dual DVI Mini HDMI PCI-E Graphics Card
http://www.ebuyer.com/254405-asus-gtx-560ti-directcu-ii-1gb-gddr5-dual-dvi-mini-hdmi-pci-e-engtx560-ti-dcii-2di-1gd5
Corsair Vengeance 16GB (4x4GB) 1600 Mhz CL9 1.5V Non-ECC Unbuffered
http://www.ebuyer.com/248759-corsair-vengeance-16gb-4x4gb-ddr3-1600mhz-cl9-1-5v-non-ecc-unbuffered-cmz16gx3m4a1600c9
Arctic Power 700W PSU - 4x SATA 1x PCI-Express
http://www.ebuyer.com/124927-arctic-power-700w-psu-4x-sata-1x-pci-express-p2-arctic-700td
Creative Sound Blaser X-Fi Xtreme Audio 7.1 PCI Soundcard
http://www.ebuyer.com/190498-creative-sound-blaster-x-fi-xtreme-audio-7-1-pci-soundcard-70sb079002007
WD 2TB 3.5" SATA-III 6GB/z Caviar Green Hard Drive - 64MB Cache
http://www.ebuyer.com/264274-wd-2tb-3-5-sata-iii-6gb-s-caviar-green-hard-drive-64mb-cache-wd20earx
Arctic Cooling Freezer 7 Pro rev 2 Socket 1155 Heatpipe CPU Cooler
http://www.ebuyer.com/176157-arctic-cooling-freezer-7-pro-rev-2-socket-775-1156-1155-1366-ac-frz-7pr2
NZXT Phantom Full Tower extended ATX black USB/AUDIO/E-SATA
http://www.amazon.co.uk/product-reviews/B003WE9WQY/ref=dp_top_cm_cr_acr_txt?ie=UTF8&showViewpoints=1
Casecom 150mm Blue LED Case Fan 3 and 4pin Connection
http://www.ebuyer.com/225778-casecom-140mm-blue-led-case-fan-3-and-4pin-connection-140mm-blue-fan
Coolermaster MegaFlow 200mm Transprent Red LED Silent Fan
http://www.ebuyer.com/205467-coolermaster-megaflow-200mm-transprent-red-led-silent-fan-r4-lus-07ar-gp
LiteOn iHAS224 24x DVD±RW DL RAM & Lightscribe SATA Optical Drive
http://www.ebuyer.com/190838-liteon-ihas224-24x-dvd-rw-dl-ram-lightscribe-sata-optical-drive-ihas224-19
I'm not sure really what websites to buy parts from.
Again thanks in Advance
3 answers Last reply
More about compatibility check help
  1. Thanks a Lot
  2. May I ask what do you mean by "animating" if you mean watching anime, then an i7-2600k would be overkill, modern games (2011 and before titles) do not utilize more than 4 cores. An i5-2500k would definitely save you quite a few pounds / bucks.
    As for UK sites, www.overclockers.co.uk is pretty solid, so is amazon, obviously. ^.^"
    As for case fans, I have only use a few
    http://www.overclockers.co.uk/showproduct.php?prodid=FG-013-CM&groupid=701&catid=57&subcat=4
    and
    http://www.overclockers.co.uk/showproduct.php?prodid=FG-010-CM&groupid=701&catid=57&subcat=4
    and
    http://www.overclockers.co.uk/showproduct.php?prodid=FG-001-FD&groupid=701&catid=57&subcat=4
    They are extremely quiet and "sufficient".
    As for CPU cooling, I would suggest the Corsair H80 or even the H100...
    Here is the review tomshardware did for them.
    http://www.tomshardware.com/reviews/h2o-h80-h100-benchmark-overclocking,3084-8.html
New Build Compatibility Systems
