i got this problem suddenly after years of running my laptop without a problem
i started to get blue screen issue , so after days of figuring out where the problem comes from
i ended up with this:
if i remove one of the two rams no matter which dimm or which slot
everything works fine no blue screen
whenever i insert two rams at a time this problem occurs i even inserted different rams from different laptops
there r no options to change ram voltage values in bios
my windows laptop is running 2GB (2x 1GB) ddr2 rams with max of 4GB (2x 2GB) is possible as crucial website says
whats the problem with my laptop??? im guessing a motherboard problem? if so why is it that both slots work fine just not the two at a time? remember the laptop was just fine for years it all started suddenly
