Archived from groups: rec.photo.digital (More info?)
utseay@aol.com wrote:
> I use to have the Canon Powershot s400, and I have to say I was
> impressed with the quality. Although the quality was great - there was
> RED EYE in every single picture. I couldn't take it any longer, so I
> got the Sony Cybershot DSC-P200 7.2 megapixel. The quality is great,
> and NO REDEYE. The bad news is, the picture clearity is 50/50. Half
> the time it takes a great picture, the other half a blurry picture. I
> had zero blurry pictures with the s400. After last night at a party
> that contained many blurry pictures that I really wanted I've decided
> to get rid of the Sony.
> My question is, what do you guys suggest for quality and consistant
> clearity with little red eye?
The deciding factor for red eye is the distance between the lens and the
flash and the subject, or pre-flash red-eye reduction. Are those two
cameras very different sizes or flash positioned differently?
Blur may be caused by a number of things, probably too long of a zoom??
Do you have an example with EXIF shooting settings?
