PC won't power on
One morning my pc wouldn't turn on after running just fine the night before so I did some research. I believed I had found the solution, the power supply. I RMA'd the corsair power supply, got the new one, and plugged it in. Still nothing.
Then I started troubleshooting the system piece by piece. Unplug a component and see if it works. I got the HDD and optical drive unplugged and the fans spun up for just a second. I had bumped a cable. I touched the cable again and the fans spun up again. I pushed the cable into the connector just to make sure it was secure and the system spun up and stayed running.
I shut it down, reconnected the HDD and optical drive, and powered it back up. It worked. I used my pc for a couple hours then shut it down.
A couple days later when I tried to use it again it will not power up. I check the connections again, still nothing. I remove everything but the mobo and cpu, still nothing.
Any ideas what could be wrong? Is the mobo bad? It's a Gigabyte Z68xp-ud3, http://www.newegg.com/Product/Product.aspx?Item=N82E16813128512
Thank you for any help.
4 answers Last reply
More about power
  1. The CMOS battery could be failing. This battery is a CR2032, and can be purchased just about anywhere batteries are sold (radio shack, wal-mart, target, etc.).
    I would also consider doing a breadboard (build everything outside of the case).
    You can find a step-by-step tutorial at the end of the troubleshooting guide. Click on the link in my signature.
  2. Hello... inspect the pins/sockets of your suspect cable/connector... and adjust/clean/align/tighten the electrical connections there?
  3. I did double check the pins and made sure all of the connections were solid. I should have added that the suspect cable/connector is the 24 pin slot. Both the connector and the cable are in perfect shape and I pushed it into place as hard as I was willing to to make sure it was a solid connection.
    I will try breadboarding it, if it still fails I will pick up a CMOS battery and try that. Does the battery have to be a certain one or would any CR2032 work?
    Thank you.
  4. any brand will do, so long as it is a CR2032.
Motherboards Power Supplies Product
