This are Asrock's new Mobos which are based on the P35 Chipset but the company claim that it supports FSB up to 1600 & also DDR3 1600...
This is a good mobo for future proof....when DDR3 becomes mainstream, you could easily buy a pair of 4GB DDR3 1600 without buying a new mobo...Also when the last of the Penryns (FSB 1600) is release, it is also compatible...
http://www.asrock.com/mb/overview.asp?Model=4Core1600P35-WiFi%2b&s=n
http://www.asrock.com/mb/overview.asp?Model=4Core1600P35-WiFi&s=n
This is the advantage of having the memory controller on the mobo, you can put different dimms, DDR2/DDR3 just like in the Pentium 4 days where there are mobos with SDram/DDR....
