First Gaming Build [Need advice)
Hey everyone, I'm building my first Gaming computer in a month and just wanted some advice on the components i chose. Any help or corrections on compatibilty would be great. I included the links just in case i need any corrections.
CPU: AMD HDX830WFK4DGM Phenom II X4 830 Processor(Quad Core, 2.80 Ghz, 6mb L3 Cache, 2mb L2 Cache) http://www.compusa.com/applications/SearchTools/item-details.asp?EdpNo=1455495&sku=A79-0830
Motherboard:Biostar TA870U3+ AMD 870 Motherboard http://www.compusa.com/applications/SearchTools/item-details.asp?EdpNo=7265659&sku=B450-2425
Video Card: Galaxy 55NGH8HX4NXK GeForce GTX 550 Ti Video Card (Nvidia) http://www.compusa.com/applications/SearchTools/item-details.asp?EdpNo=7335353&Sku=G458-0550
RAM: Corsair CMX4GX3M1A1333C9 XMS3 4GB DDR3 RAM(two of them my PSU comes with one) http://www.compusa.com/applications/SearchTools/item-details.asp?EdpNo=6613461&sku=C13-1005
Data hard drive: Western Digital WD5000AAKX Caviar Blue Hard Drive - 500GB, 3.5"(SATA 6 Gb/s, 7200 RPM, 16 MB) http://www.compusa.com/applications/SearchTools/item-details.asp?EdpNo=7281716&sku=TSD-500AAKX
OS & Programs hard drive: Western Digital WD2500AAKX Caviar Blue Hard Drive - 250GB, 3.5"(SATA 6Gbps, 7200 RPM, 16MB) http://www.compusa.com/applications/SearchTools/item-details.asp?EdpNo=160418&sku=TSD-250AAKX
PSU: Corsair 600W Builder Series™ CX600 V2 80 Plus PSU http://www.compusa.com/applications/SearchTools/item-details.asp?EdpNo=1753650&sku=C11-1122
I'll be hooking it up to a 32" 1080p HDTV since I plan on using it as a Gaming system and a home theater(plus i can't afford a good monitor right now). I'm still looking for a case but i'm waiting till last minute for that.
Edit: Due to unavailability and research deeper i changed my CPU, PSU, Motherboard.
4 answers Last reply
More about first gaming build need advice
  1. Its a good build. Good luck.
  2. The disk selection is unusual. You've linked a 2.5in 5400 rpm drive as your system drive? That will need an adapter to fit in your PC, and it's a slow low power drive used in laptops ?
    Looks like a fine, balanced gaming build.
    Your 32" 1080p HDTV is as good as or better than any monitor you might buy later. And it may have OK sound if you use HDMI to connect. Just find the right seating position for web surfing.
    I figured that the 2.5" drive was a little wierd. And As far as the sound goes i have my TV set up with 5.1 Dobly surround. Thanks for letting me know
  4. You might want to consider an HD6770 (HD5770). At least the same performance but cheaper.
Homebuilt Gaming Systems
