Closed Solved
Power supply choice for i5-2400 + gtx560ti
Is the CX500 good enough for:
i5-2400
GTX 560 TI
8gb ram (4gbx2)
1 SSD
DVD burner
I ask just to save a lil cash and is part of a case bundle. With the bundle it is about $48 saved.
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.838509
CORSAIR Builder Series CX500 V2 500W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139027
or
CORSAIR Enthusiast Series TX650 V2 650W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139020
7 answers Last reply Best Answer
More about power supply choice 2400 gtx560ti
  1. yes, that's plenty of power in my opinion.
    Maybe Ko88 can't give you a closer figure on that.
  2. The 500W is plenty.
    This system is with an i7-920 (130W) + ~39% OC.
  3. Here's a PSU calculator for use in the future:
    http://www.thermaltake.outervision.com/
  4. CX500 will do the job..
  5. CORSAIR Builder Series CX500 V2 500W is your best buy -- if you are not planning to SLI in the future.
  6. Best answer
    For a system using a single GeForce GTX 560 Ti graphics card NVIDIA specifies a minimum of a 500 Watt or greater power supply that has a combined +12 Volt continuous current rating of 30 Amps or greater and that has at least two 6-pin PCI Express supplementary power connectors.
    Total Power Supply Wattage is NOT the crucial factor in power supply selection!!! Total Continuous Amperage Available on the +12V Rail(s) is the most important factor.
    The Corsair Builder Series CX500 V2 (CMPSU-500CXV2), with its combined +12 Volt continuous current rating of 34 Amps and with two (6+2)-pin PCI Express supplementary power connectors, is sufficient to power your system configuration with a single GeForce GTX 560 Ti.
    Although the Corsair Enthusiast Series TX do have a higher quality and longer warranty period.
  7. Best answer selected by blbeta.
Power Supplies Intel i5 Corsair Components Product
