20 pin to 24 pin MoBo power
I have a old home system w/ this MoBo: http://h20000.www2.hp.com/bizsupport/TechSupport/Docume...
and i soon will be adding this gfx card: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
i have a older 250 watt psu and its using a 20 pin connector for the MoBo, i hear the difference between 20 pin & 24 pin is that 24 pin has more power. So since my MoBo can take a 24 pin connector and ill be adding a low end gfx card w/o separate power connector, should a get a 20 pin to 24 pin adapter to help power the gpu?
More about : pin pin mobo power
It would seem Sapphire recommends a 400w power supply as a minimum (though you MAY be able to run this card, it will not work very well and I would NOT recommend it). Many of these low end cards require no additional power connecters but instead draw power from the motherboard itself, requiring more power to be fed directly into the motherboard. I would look into getting a 400+ watt power supply to amply run this card.
