Long story short my Seasonic x660 bit the dust and died last night so im currently getting it rma'd.
I need a temporary replacement for the time being and the OCZ 500W ModXstream Pro is currently $35 (after mir) at my local re-seller.
My System Specs:
i3 2100
Gigabyte HD 6850
4GB DDR3
60 GB SSD
320 GB
Dvd-RW
On paper it should be ok, but i noticed the 500w modstream (see chart below) has a combined 12v of only 432w. The Min wattage on the Gigabyte HD6850 is 500w.
Will it be ok?
**EDIT I ended up getting the 600w for $10 more just to be on the safe side.
My System Specs:
i3 2100
Gigabyte HD 6850
4GB DDR3
60 GB SSD
320 GB
Dvd-RW
Will it be ok?
