Solved
Compatible Parts needed for Gaming PC
APPROXIMATE PURCHASE DATE: within a month
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Gaming & Surfing
PARTS NOT REQUIRED: Keyboard, Mouse, Windows 7 64 bit OS, Monitor, Audio System, Hard Drive, Optical Drive (DVD)
PREFERRED WEBSITE(S) FOR PARTS: Dell (US) [Simply to spend a $200 Gift Card)
PARTS PREFERENCES: None
OVERCLOCKING: Does not matter.
MONITOR RESOLUTION: 1366 x 768
ADDITIONAL COMMENTS:I am looking to build a Gaming PC. I am pretty new to the world of hardware as I am more of a software guy. The two parts i have picked out that I am hoping to get are
Motherboard/Processor: http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=1270248&csid=ITD&body=MAIN
and
And GPU: http://accessories.us.dell.com/sna/productdetail.aspx?c=us&l=en&s=dhs&cs=19&sku=A2471188&~ck=baynoteSearch&baynote_bnrank=12&baynote_irrank=0
Any information that can be given would be extremely helpful. I was looking for answers on compatibles brands/parts. But if anyone would be kind enough to help me assemble a list to build the rest of the PC (Case, Power Source, and Other such things). Thank you so much!
Edit: I am attempting to stay under $500 dollars.
3 answers Last reply Best Answer
More about compatible parts needed gaming
  1. Best answer
    So the total budget will be $500 and $200 of it is in the form of a Dell gift card? The parts needed would be motherboard , cpu , gpu . video card and ram?
    AMD FX-4100 Zambezi 3.6GHz (3.8GHz Turbo) Socket AM3+ 95W Quad-Core Desktop Processor FD4100WMGUSBX
    $119.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819103996
    ASRock 970 EXTREME4 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard with UEFI BIOS
    $109.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813157262
    Antec NEO ECO 520C 520W Continuous Power ATX12V v2.3 / EPS12V 80 PLUS Certified Active PFC Power Supply
    $59.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817371030
    GIGABYTE GZ-F2HEB Black SECC Steel / ABS ATX Mid Tower Computer Case
    $24.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811233071
    CORSAIR XMS3 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMX8GX3M2B1600C9
    $44.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820233202
    Total at Newegg $359.95.
    http://accessories.us.dell.com/sna/productdetail.aspx?c=us&l=en&s=dhs&cs=19&sku=A5182107&~ck=baynoteSearch&baynote_bnrank=0&baynote_irrank=0 $139.99
    http://accessories.us.dell.com/sna/productdetail.aspx?c=us&l=en&s=dhs&cs=19&sku=A4136068&~ck=baynoteSearch&baynote_bnrank=6&baynote_irrank=0 $184.99
    These two video cards are better than the one that you had listed so it will be your choice on the card.
  2. Wow, this is an extremely helpful list Inzone! This is a ton of help! Thank you a lot for this! As well as the video cards!
    It'll be a lot of help! :)
  3. Best answer selected by thatOneMarcus.
Homebuilt Gaming Compatibility Systems Product
