Hey guys, first time builder here. I've decided on the processor I want to use (i5-2500k 3.3 Ghz) and I'm fairly sure I'll be going with the ASRock Z68 Extreme3 Gen3 for the MoBo. Depends on what kind of deals newegg has on Black Friday when I'll be buying everything.
I want to run BF3 and eventually Diablo 3 as well as whatever games I may what to play later on. Basically, I'm looking for a good gaming card. I have about $250 bucks to work with and from what I've gathered, the ATI 6950 2GB and the Nvidia 560 1GB are the best options out there. I've heard from a friend that the 6950 can be unlocked to run at the speed of a 6970 but I don't know much about that.
Wondering what your guy's thoughts were. Don't plan on running dual cards because I don't have the money for it. What do you think is the best card for me?
Also curious about the compatibility between a PCIe 2.0/1 card and a PCIe 3.0 slot or a PCIe 2.1 card and a PCI 2.0 slot. Need some education from you guys!
I'd appreciate any help.
