My 1st build..plzz help
gherr74
57
hey guys , and ladies.. i am doing my 1st build, and was seeing if you guys can help me out a lilbit. my 1st chioce is
Core i7-960 3.2GHz
ASUS Sabertooth X58 LGA 1366 X58 ATX Intel Motherboard
Patriot Extreme Performance Gaming Series 6GB DDR3-1600 Enhanced Latency Triple Channel Ram
2 TB 7200 RPM 64MB Cache SATA 6.0Gb/s HDD
Corsair TX750 V2-750 Watt PSU
OR My 2nd choice
Core i5 2500K
ASROCK Z68 Extreme3 Gen3 LGA 1155 Z68 ATX Intel Motherboard
CORSAIR Vengeance Series 16GB DDR3-1600 Dual Channel Ram
( and i will not be overclocking, everything stock, intill i learn how to overclock..lol )
videocard comes 2 weeks later. prolly ati 6950 or 6970 hd card
i will be doing gaming and video editing, so what would be best set-up.. thanks guys for any help you can give..
aicom
923
OK, your first choice is based on the outdated LGA 1366 platform (succeeded by the LGA 2011 platform). Your second choice is much better. It will give you better performance now and the ability to upgrade to Ivy Bridge later this year. For your GPU choice, if you're aiming at the 69xx series of GPUs, I'd recommend the 78xx series that was recently released. These cards will generally outperform their previous generation counterparts and do it using significantly less power and heat. The price right now is a bit high but I can tell you from experience that I'm very happy with my purchase (I own the 7870).
^as he said,sandy bridge 1155 platform is better than 1366.from you second choice,minus 8gb of ram.DDR3 1600mhz 8gb is more than enough.gtx 680 for $500 is a great deal but if you are not willing to spend $500 than wait for 660ti or 670.69xx are hard to find and are replaced with 7xxx cards.i hope,in two weeks,670 will be out.
MegaMan1
163
This week lots of SSD on sale for dollar a gig. Go with SSD boot 60 to 120 gb. No 1 thing Windows pc does most often is boot. Put system on SSD and rest on 2 TB. Save much time on virus scan and other things too.
