So hi all. I recently bought a rig on 23rd february ( about a month and a week ago ), and everything is working fine except the sound produced from my headphones OR speakers has a soft buzzing pszzzzz sound. It exists even if i mute the sound, and is present at the same noise level despite increasing/decreasing the volume meter.
The headphones i use is a seinheisser HD 415 ( sorry if i spelt the brand wrong )
Speakers I use is logitech speaker Z103 ( a woofer and 2 mini side speakers ).
The sound is clearly produce from my headphones OR speakers... as if i dont wear the headphones, there is no sound, or if i dont use any AUDIO device there is no sound.
I use Realtek HD Audio manager
driver version 6.0.1.6423
Im using the onboard graphics of motherboard gigabyte z68ap-d3
Im a pretty poor university student, so i really wanna know if getting a dedicated sound card solves it or I should just do some minor tweaking and save money .
in any case, you might need my system specs, its an i5-2500, some kingston ddr3 1300mhz 8 gigs, a 560 ti, a WD blue 500 gb HDD, and some 500 watts CM PSU.
thanks in advance !
thanks in advance !
