Problems with new build
Last response: in Systems
I have a test setup consisting of a P67a-G45 motherboard, 2x4gb Corsair Vengeance RAM, i5-2500k 3.3ghz and a Radeon HD 6950 2gb (although I have tested without the GPU and the same happens).
When I start up the test, everything turns on, fans, all 4 CPU LED indicators (for the mode or something), but instead of a post beep, I guess 2 beeps, a higher beep, then 3 or 4 lower longer beeps. I have not been able to find any info on this beep code, so I'm hoping someone here might be able to help. Thanks in advance.
More about : problems build
Ask the community
