Need an expert opinion on my chosen parts...
Hi there,
Are these parts firstly compatible and secondly is this motherboard average? Is there no way of having both GPU cards running at 16x ?
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131702
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233183
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150549
Is there any point getting the expensive ram like above? Or should i rather go with cheaper ram?
What is this new quad-channel ram? And is it worth getting... obviously the motherboard would have to support it. And should i rather get 2gb modules with lower timings?
I use my computer for gaming and HD media.
My main concern is the motherboard :/
5 answers Last reply
More about need expert opinion chosen parts
  1. Quote:
    No - most motherboards haven't been tested natively with 1866 yet - most can only achieve that speed through overclocking. Using speeds beyond what your motherboard can handle could spell bad news in the long run. A typical Sandy Bridge build will require dual channel (2 sticks) RAM with speeds 1600MHz timing 9-9-9-24. Now the thing is that most motherboards by default will run at whatever it can handle, but you don't want to go over what the manufacturer specifies.
    This would be better RAM and would save you quite a bit: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
    Quad channel RAM is only for systems running Intel's new X79 chipset / socket 2011 (SB-E processors only). It requires four sticks to get the most functionality out of it, as opposed to the typical dual channel system.
    And to answer the second question - not really since like I said by default your motherboard will run the lowest speeds and timings it can handle, and OC'ing your RAM to run at anything other than stock speeds will spell bad news in the long run.
    I like Asus boards, but I am not a fan of the Sabertooth. I'm not sure what they were thinking with that one.
    This would be a better board for the price (same one I have): http://www.newegg.com/Product/Product.aspx?Item=N82E16813128506
    If you want to stick with Asus this would be the board I would recommend: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131790
    That depends on your motherboard's feature set. Compatibility isn't something you really need to worry about. A typical Z68 or P67 motherboard will, by standard - it will have at default 2 x PCI-e x 2.1 x 16 slots. Some motherboards will have more or less depending on what you're going for, and what your price range is.
  2. Thanks alot g unit i recon ill just go with the gigabyte :) .
  3. Just been looking at cases and PSU,...
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811129087
    This case looks pretty badass and has some good reviews i also like the bottom mounted PSU.
    Will this work? http://www.newegg.com/Product/Product.aspx?Item=N82E16817371049
    I have a 750W Thermaltech PSU back in south africa but its 3-4 years old, I had to buy it for my 2900XT which required a 8 pin adapter. Would it be better just getting rid of that and getting a new PSU. I wouldnt be able to tell you the model number, but im probably safer buying a new one :) thanks alot for all the help.
  4. Quote:
    http://www.newegg.com/Product/Prod [...] 6811129087
    The DF-85 isn't a bad choice for sure - but the thing about full towers is that they're difficult to transport. Try something like this: http://www.newegg.com/Product/Product.aspx?Item=N82E16811139010
    Quote:
    Will this work? http://www.newegg.com/Product/Prod [...] 6817371049
    Not a bad choice either. The bad thing about using PSUs from a foreign country is that their power standards might not meet the US power standards. I'd think something like one of these would be a better fit:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817171057
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817151087
  5. Thanks again for the help.
    I ended up ordering from tiger direct, I got,
    2 x HD 6950 2GB MSI twin frozen edition
    i5 2500k
    Corsair Vengeance 16GB PC12800 DDR3 1600MHz 4x4
    OCZ Vertex 3 120GB SATA III 2.5" SSD
    850W CoolerMaster PSU
    MSI P67A-GD65 B3 Intel P67 Socket 1155
    http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=40755
    Thanks for all the help :)
    By the way tiger direct are useless.
New Build RAM Motherboards Systems Product
