First build -- motherboard, case and GPU advice
Approximate Purchase Date: Next 2 weeks
Budget Range: $800-900 Australian dollars
System Usage from Most to Least Important: Coding,gaming,folding@home,image editing
Parts Not Required:
Hard drive, monitor,keyboard,mouse
Preferred Website(s) for Parts:
I'm getting most of my stuff locally except maybe the RAM
amazon.com
Country: Australia
Overclocking: Yes
SLI or Crossfire:
No
Monitor Resolution: 1280x1024 (I want to buy 2 additional monitors when i can afford it.)
Additional Comments:
Don't really care about noise unless it's too outrageous, Must be Linux compatible
Parts already Chosen:
i5 2500k
http://ark.intel.com/products/52210/Intel-Core-i5-2500K-Processor-%286M-Cache-3_30-GHz%29
Corsair Venegance 8gb Kit
http://www.corsair.com/memory-by-product-family/vengeance/vengeance-8gb-dual-channel-ddr3-memory-kit-cmz8gx3m2a1600c9b.html
Samsung DVD Burner SH22AB
http://www.shopbot.com.au/pp-samsung-sh-222ab-price-313644.html
Hello,
hoping for some advice on my first build.
I'm building myself a computer for programming and gaming.
I'm not going going be running any of the newest DX11 games, and not at very high resolutions.
However I need a card that can cope with three monitors.
It also needs to be Linux (Ubuntu) compatible, does this mean I need Nvidia cards as they are better supported on Linux?
I've looked at chipsets and deemed the Z68 to be the most appropriate as i can OC and use the integrated graphics before I buy a GPU
With the motherboard, i need to decide between:
ASRock Z68 Exteme3
ASUS P8Z68-V LE
ASUS P8Z68-V LX
With the case, i can't decide between
Cooler Master HAF 912 Advanced and other PSU
http://www.coolermaster.com/product.php?product_id=6679
Cooler Master Elite 431 Plus (with 500w PSU)
http://www.coolermaster.com/product.php?product_id=6737
Corsair 500R
http://www.corsair.com/pc-cases/carbide-series-pc-case/carbide-series-500r-white-mid-tower-case.html
If there are any obvious options I've missed, please suggest them
Thanks,
-tim
15 answers Last reply
More about first build motherboard case advice
  1. For the board, the ASRock would be my choice of those three. You have verified that it will work fully with your Linux distro?
    You seem to be kind of blowing off the PSU choices. Don't do that. You are asking for trouble.
    Here's a decent PSU
    http://www.pccasegear.com/index.php?main_page=product_info&cPath=15_226&products_id=15135
    Your case choices are varied. At the apparent price of the Corsair case you can get a Silverstone Raven
    http://www.pccasegear.com/index.php?main_page=product_info&cPath=25_1290_608&products_id=18478
  2. Quote:
    You want to go Eyefinity then if you plan on running multiple monitors. Try the Sapphire Flex series as they'll allow you to run multiple monitors in HDMI at the full 1080p resolution instead of DVI.
    Both Radeon and GTX should be supported on Linux but that all depends on the individual card manufacturers and whether or not they provide Linux drivers.
    If you're going to run multiple monitors - the onboard GPU will only be able to run one monitor at a time and will run off of either VGA or DVI, most motherboards don't support HDMI yet.
    Totally agree here. If you get the wrong PSU - it could mean bad things later on. This would be the best PSU for the money:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139028
    Don't think you can find monitors with that resolution natively anymore unless you're already using one. If you buy a new one it should be HDMI - 1080p or nothing.
    ASRock Z68 Exteme3
    ASUS P8Z68-V LE
    ASUS P8Z68-V LX
    Of those choices go with the Asus LX. If you want to look at any other - try Gigabyte.
    http://www.coolermaster.com/produc [...] ct_id=6679
    http://www.coolermaster.com/produc [...] ct_id=6737
    Corsair 500R
    http://www.corsair.com/pc-cases/ca [...] -case.html
    Go with the Carbide 500R if you can afford it, if not then go with the HAF 912. Both are excellent choices. But do *NOT* get one with a built in PSU - that could mean bad things initially and down the road.
  3. Thanks.
    I'll get the HAF 912 normal, i've decided
    I'm looking about for info on Linux and the ASrock, but i hope so.
  4. Thanks for the advice.
    I'll post a final list of parts later on
  5. If you hadn't selected poll as the post type you could have given G-unit a best answer :)
    I'll just dig up an old thread and award it to him so that he gets rewarded :)
  6. I can't find any evidence of Linux drivers on the Sapphire site or the greater interwebz. Any other suggestions.
    (I wouldn't be gaming with three monitors, just coding and surfing.)
  7. Well, what do you want to spend?
    Quadro officially supports Linux
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814195086
  8. $200-250 us
  9. I don't really think I need a specialist GPU.
    I can plug my existing VGA monitor into the motherboard and then plug 2 more displays into a normal Nvidia GPU.
  10. So far:
    i5 2500k
    HAF 912
    Corsair Venegance 8gb Kit blue
    Corsair CX600 PSU
    Asus P8Z68 LX mobo
    Samsung SH-222AB DVD drive
    I'm assuming nothing can go wrong with the disk drive on Linux as it is SATA?
  11. Should not be an issue.
    You can't run two different graphics drivers simultaneously I think, not even in Linux. You'll need at least a single triple-capable card. see this thread
    http://ubuntuforums.org/showthread.php?p=10264174#post10264174
    5770
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814127490
    Or 6770, same deal
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814102940
  12. Thanks for all your help.
    Is it possible to get a graphics card with 3 of the same port?
  13. Yes, but I think you are back to the same price range as the Quadro.
    So you have to get a dual DVI card
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814161387
    And an adapter... has to be "active" according to my understanding
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814999032
  14. Thankyou for all your help.
    -tim
  15. *bump*
    Thankyou for all your help, it works great.
    Prime95 @ 57C :)
    -tim
New Build Systems Product
