What do I need in a Motherboard?
Hey there. I am looking to build a decent gaming computer in a low budget (750$ would be pushing it, without including a monitor, mouse, keyboard, or tower). I need a good motherboard, but I have absolutely no clue what to look for. I am pretty set on the following configuration, and all I really need is an idea for a motherboard, but if you see anything that I should change, let me know. Oh, and I don’t know much of anything about RAM either, so my current choice is a tentative one. Advice on that would be welcome as well.
CPU: AMD Vishera Fx-6300 6-core for 129.99
Motherboard: ???
RAM: Patriot Intel Extreme Master 8gb for 47.99 - not sure on this one, either
Graphics: AMD HD-7850 Radeon 2gb for 199.99
Hard Drive: WD Black 500gb 7200 RPM SATA 6mb cache for 64.99
Power Supply: Rosewill Green Series Rg630-S12 630W for 59.99
I am not planning on doing crossfire or overclocking, but I would prefer to have those features available so I have room to expand later if I want to. Thank you so much for the help!
By the way, I know very little about building computers, so please be patient and forgive any sort of ignorance I might show. Sorry.
7 answers Last reply
More about what motherboard
  1. Wow. Thanks for the speedy response!
    Quick question, though, to help me learn and understand: What about that board makes it a good one?
  2. First, does it support all of the other parts at a base level.
    Next, does it optimally support all of your parts? (PCI-E 3, SATA 3, RAM speed, etc)
    There are other factors such as warranty and brand, but if you're going for functionality on a budget, know that the difference between support and optimal support is what makes a good motherboard a great motherboard.
    Would you agree, then, that the board suggested by Blackbird (asrock 970 extreme3 6gb/s) is a good one for my configuration?
  4. Yes it will fit your needs.
  5. http://www.asrock.com/mb/AMD/970%20Extreme3/
    Here is the site with more info on the board.
  6. Thank you! I think I'll add that to my list.
Motherboards Product
