Solved
Case help
Stuck between 3 highly praised cases
Antec Nine Hundred Black Steel ATX Mid Tower Computer Case - 89.99
Antec Three Hundred Illusion Black Steel ATX Mid Tower Computer Case - $69.99
Antec Three Hundred Black Steel ATX Mid Tower Computer Case - $54.99
Also which one(s) can support ...
This Motherboard: GIGABYTE GA-Z68XP-UD3P LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
This Gpu: MSI N560GTX-Ti Hawk GeForce GTX 560 Ti (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
Thanks in advance. I've seen reviews but I could use some more community knowledge.
6 answers Last reply Best Answer
More about case help
  1. In nine hundred you will have a lot more space than three nundred.
  2. The one I hear people raving about most out of those 3 is the Illusion case.
    I was going to get a 300 Illusion myself, but then I found a deal that was too good to pass up on a Lian Li case. I am glad I took the deal.
  3. Best answer
    The Illusion is the 300 with two fans added to the front . You can do this your self .
    The 900 is only marginally taller than the 300 and most of that is the top fan surround.
    900=====• 19.4" (H) x 8.1" (W) x 18.4" (D)
    300=====• 18" (H) x 18.3" (D) x 8.1" (W)
    Of the 3 I like the 300's understated looks and I'd add a couple of quiet fans to the front . Fans that dont have the blue LED's
  4. The illusion and the 300 are the same case. Just one comes with lighted fans. Is that worth $15? Then you need to decide if the 900 is worth the extra $$$ as well. 300 lacks water cooling hose outlets, and cable management.
  5. All the fans on the 300 illusion (4) have speed control.
    It isn't that horrible for only $15 more.
    Anyway, I never hear people talking about the 300 regular, or at least 10x less often as the Illusion case anyway.
  6. Best answer selected by Darklum.
New Build Cases Computer ATX Systems
