Hello,
I am building a gaming rig and I want as much as possible to max out most games with a 22inch monitor.
SO i went and tried to buy the following:
core i5 2500k
8gb g-skill ripjaws x
MSI Gtx 570 twin frozr 3 PE/OC.
But the gtx 570 was nowhere to be found. I think this is the best performance/value that I can get which is priced at $428.
I looked into the other cards but i cannot decide which one to get. Below is the details.
Inno3d gtx 570 gamepack - $369 - not sure about this card. i only trust msi/asus/evga
asus 6970 direct cu 2 - $440 - after checking out benchmarks, i realized it runs slower than gtx 570 twin frozr 3
Evga gtx 580 - $595 - not also sure about this because of the jump in price. do you think its worth it?
msi gtx 560 ti - $297 - maybe my last resort, maybe buy a 19inch monitor so i can run games at 1366x768 for performance boost
P.S.
THe prices are a bit higher because I live in the Philippines. Please also dont recommend SLI because I have fixed my mind to go for the single card route.
Thanks in advance.
core i5 2500k
P.S.
Thanks in advance.
