G
Guest
Guest
Hey everyone. This is the first real build I'm planning so I would really appreciate any advice and help.
Motherboard: ASRock 970 EXTREME3 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard http://www.newegg.com/Product/Product.aspx?Item=N82E16813157280
CPU: AMD Athlon II X4 640 Propus 3.0GHz Socket AM3 95W Quad-Core Desktop Processor ADX640WFGMBOX http://www.newegg.com/Product/Product.aspx?Item=N82E16819103871
RAM: G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL9D-8GBRL http://www.newegg.com/Product/Product.aspx?Item=N82E16820231311
PSU: COOLER MASTER Silent Pro M600 RS-600-AMBA-D3 600W ATX12V V2.3 SLI Certified CrossFire Ready 80 PLUS Bronze Certified Modular Active PFC Power Supply http://www.newegg.com/Product/Product.aspx?Item=N82E16817171036
GPU: Already have a Radeon HD6770
HDD: Seagate Barracuda ST500DM002 500GB 7200 RPM 16MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive www.newegg.com/Product/Product.aspx?Item=N82E16822148767
Approximate Purchase Date: February 2012
Budget Range: 400-500
System Usage from Most to Least Important: Gaming
Preferred Website(s) for Parts: newegg, but open to other
Country: Argentina. Everything will be bought in the US
Parts Preferences: AMD CPU/VideoCard
Overclocking: Maybe
SLI or Crossfire: Maybe
Monitor Resolution: 1920x1080
Additional Comments: I cannot go over 500$ under any circumstances. Intel and Nvidia won't be considered for this build. My intention is to change the CPU ASAP, but given my limited budget I have to buy a mid-end one first.
Overclocking: Maybe
