Need Help!! Will these components work together?
Last response: in Systems
I am currently building my own computer for my university course and gaming that I do. My course requires some serious rendering software.
Will these parts work together:
Case NZXT Phantom - http://www.ebuyer.com/240815-nzxt- [...] -phan001wt
Motherboard Asus P8P67 Pro - http://www.ebuyer.com/282891-asus- [...] o-rev-3-1-
Processor Intel i7 Sandybridge 2600k - http://www.ebuyer.com/252535-intel [...] 623i72600k
Memory Corsair 16GB - http://www.ebuyer.com/262586-corsa [...] m4a1600c9b
Graphics PowerColor HD 6970 2GB - http://www.ebuyer.com/280423-power [...] -2gbd5-2dh
Hard Drive WD 1TB 3.5" SATA-III 6Gb/s Caviar Black - http://www.ebuyer.com/193712-wd-1t [...] wd1002faex
SSD For Boot OCZ 60GB Agility 3 - http://www.ebuyer.com/268239-ocz-6 [...] 25sat3-60g
PSU OCZ ZX Series 1250W 80+ GOLD - http://www.ebuyer.com/265711-ocz-z [...] zx1250w-un
Blu Ray Drive LG BH10LS30 - http://www.ebuyer.com/195145-lg-bh [...] 0ls30-auar
Heatsink Coolermaster Hyper 212 Evo - http://www.ebuyer.com/297389-coole [...] 2e-16pk-r1
More about : components work
Will they work together? Yes. But it could definitely use a bit of tweaking:
You do *NOT* need a 1250W PSU for this build. This would be a far better choice and will probably save you $100: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Do not get the Agility 3 - I've read many reviews of this drive and they all seem to point toward the negative. Go with the Crucial M4, Intel 510, or Samsung 830 - much safer bets.
The Sapphire 6950 2GB will be a safer bet if you plan to run multiple monitors. You can run them in any number of configs with adapters and especially in HDMI. With a BIOS flash the 2GB model will perform the same as the 6970.
Other than those recommendations it looks pretty good. Just needs a couple of things that I suggested above.
Ask the community
