Will this work please help
G
Guest
Guest
hi in the next month and a bit my birthday is coming up and im planning to update my dell dimension 9200 and i just wanted a bit a nudge in the right direction its my first time upgrading my pc ive sorted the ram and processor and i have found the graphics card i want but i wanted to be sure this would work with my dell dimension 9200 if not or if there is a better one what would you recommend in the price range up to £170 for games (it needs a hdmi output as i have to connect it to a tv)
cheers
Hi guys Dell PSU's are pretty useful and will run cards that would be a instant No No on any other PSU rated the same.
Give me a bit to check the specs of the card and i will get back to you. I will say im doubtful straight off the bat. Even allowing for the PSU being pretty strong my gut instinct says it will struggle to power that card.
Mactronix :)
