Help!! My PC Display is to big
mercer95
514
Hello... iv just got a new Radeon hd 6670 from Maplins for £60, iv installed it using the disc that was provided and the display is overlaping my moniter, if you dont understand the edge of the display (where the close button and start button go) is cut off, any advice would be greatly appreciated.
also my monitor is a 23" samsung syncmaster 2333hd and im using a hdmi cable rather than a VGA caple.
Thanks Tom.
What OS are you using?
Sounds like your resolution is too big for your LCD screen.
I just did a quick check and it says your LCD supports 1920x1080 resolution. Have you tried setting it to that resolution, or lower?
