I just finished building my first pc and I bought an ASRock Z77 Extreme4 motherboard and an i5 3570K to go along with it. I put it all together and when I try to power up the system, Dr. Debug first says "20" for a couple seconds, and then displays "53". I don't see error code 20 anywhere in the manual but 53 is "No usable memory detected." I have 2 sticks of G.Skill 2133 4GB ram. There are 4 slots and I have installed them in every possible combination of slots. Always gives me "53".
this is the memory I purchased
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231468&nm_mc=AFC-C8Junction&cm_sp=&AID=10446076&PID=3938566&SID=
there is a list of compatible memory's http://www.asrock.com/mb/memory.asp?Model=Z77%20Extreme4 which mine of course is not listed on. I can buy a new memory but before I do I was wondering if it might be a problem with my mobo? l looked up which is the best memory for this mobo and a lot people recommend stuff thats not even listed on the list.
What do you guys think?
