Good day!
I've been using Catalyst 11.1a for quite some time now and everything worked perfectly. Then I upgrade to 11.9 for BF3 but during the installation I get an error...
Got no choice to continue and it seems that it installs the Catalyst but whenever I try to access it, nothing happens. It will show that it's trying to open it but then will just stop (I'm accessing it through its root folder as the option from the right click on desktop is not showing). I already tried going back to 11.1a and other versions, everything is just the same.
I already tried uninstalling through the Catalyst uninstaller, manual uninstalling and Driver sweeper then used CCleaner for the registry, still no luck.
BTW, I'm using a Sapphire 6850, Windows 7 32 bit.
Any idea what I should do?
AMD is not responding to my query so I had to post here for help. Any suggestion would be appreciated. Thanks!
Microsoft Visual C++ 2010 RedistributableFinal
Status: Fail
Version of Item: 10.0.30319
