Hey guys, got a problem thats been baffling me for a while now.
Maybe 1/20 times when I shutdown my system, the machine will power down but my BlackWidow keyboard will stay fully illuminated and my speakers will start humming as the stereo connections pick up current (The amp is permanently cranked up to 100% so the speakers will make similar noise if you touch the plugs with your fingers when the sound system is turned on).
The system will stay in this state until I physically unplug the PSU from the wall and wait ~30 seconds for the capacitors to drain. Ive shut it down at night and come back to the pc in the morning with it still doing this.
Problem occurs on both my current PSU and my old Corsair HX850. The problem occurs regardless of OC
Seems to me theres a problem with the mobo but I may just be trying to rationalize buying an 1150. Thoughts?
Motherboard: Asus P6X58D-E
CPU: Intel Core i7 930 @ 3.99Ghz|1.3V
CPU Cooler: Noctua NH-D14
Case: CoolerMaster HAF 932
Memory: 3x 2GB Corsair Dominator @ 1600 mhz 8-8-8-24
PSU: PC Power and Cooling Silencer Mk3 1200 Watt
GPU: 2x EVGA GTX 470
SSD: Samsung 840 Pro 256GB
HDD1: WD Caviar Black 2TB 7200 RPM 64MB
HDD2: Seagate 1TB 7200 RPM 32MB
OS: Windows 7 Ultimate 64Bit
