Can I use my old PC to build a new power horse?
Last response: in Systems
Hi there,
I currently have a MacBook pro but find it impossible to work on HD video when editing in Premiere or FC Pro. Just to mention post-production and effects is enough to make the computer freeze up.
I am therefore looking to create my own machine. I have looked at a heap of sites to see what I might need. I've come up with the following:
- Intel Xeon E5620 Quad Core Processor ? 2.40GHz, 12MB Cache, Socket 1366
- Kingston HyperX DDR3 1600MHz CL9 24GB DIMM Memory Module (Kit of 6)
- 650 WATT Power supply Alpine Black 650 WATT Silent Quiet PC ATX PSU
- Zotac ZT-50101-10P GF GTX 580 1536MB GDDR5 Graphics Card
As a tech noob, I'm sure I'm overshooting here but I think hey, at worst, I won't have to upgrade for a few years...
Also, I'm not even sure whether all those components can work together and have no idea where to begin looking for that type of information.
I do however have an old Sony VAIO PCV-RS series computer which I no longer use. It's still functional. Do you think I could use the case, DVD-RW drive and other components from it to make life easier?
Thanks a lot for the help. Educate me please!!
More about : build power horse
Homebuilt system Authority
I believe the intel core i7 2600k will far out perform the xeon. This is the setup I would use:
CPU: Intel Core i7 2600k $300
Graphics: 2x EVGA gtx 570 in SLI $660
MoBo: GIGABYTE GA-Z68A-D3H-B3 $130
PSU: OCZ ModXStream Pro 700W $90
Case: Antec Three Hundred $55
HDD: HITACHI Deskstar 7K1000.C 0F10383 1TB $100
RAM: G.SKILL Ripjaws Series 16GB Memory Model F3-10666CL9Q-16GBRL $75
Heatsink+Fan: CM Hyper 212+ $29
DVD-ROM: SAMSUNG 22X DVD Burner $16
Total: $1455
This is sure to be a top notch computer with the ability for the i7 to hyperthread. It'll be running 8 processes at once and is one of the best CPUs out on the market, after the extreme edition CPUs. The 2 gtx570's will be more than enough for any graphics needs, and they perform better than a single gtx 580 and I believe even better than a gtx 590. The motherboard supports SLI which is important. The power supply is from a reputable company and is more than enough for SLI. The Antec 300 case should be roomy enough for all components and it has great reviews. 1TB harddrive to store your videos. 16GB of RAM should be overkill, but for a more future-proof system. The HSF is for mild overclocking of the CPU. DVD-ROM is self-explanatory, you can change to a blu-ray read/write if you wish
Homebuilt system Expert
For your needs it seems like you want a system that can handle plenty of RAM. I would say go with a 3930k
and a motherboard with the full 8 RAM slots for maximum expandability such as this one
MSI X79A-GD65(8D) Frio Adv LGA 2011 $329.99
While you can get 64 GB of RAM (two 32GB 4 stick sets) that's a bit expensive right now. 32GB, or even just 16GB should be plenty for now though but it just depends on your budget. Since you won't be gaming though I suppose the ability to use 3 or 4GPUs isn't of much interest to you ^_^.
You won't fit such a beat in your old Sony Case, but you may be able to use your old optical drives and HD if they are SATA, but considering how cheap new DVD burners are it makes sense just to buy one. It's a good idea to buy a new 7200HD as well and if you can afford it, an SSD.
Ask the community
