BSOD problems - itunes related
I keep getting BSODs while trying to watch movies or long TV shows on iTunes - it doesn't really happen any other time. Not with games, anything. Is there something that could repeatedly cause this problem? Is it faulty connectors on my PSU to my hard drive? Anything else?
3 answers Last reply
More about bsod problems itunes related
  1. Bad PSU cable seems unlikely.
    I would be more quick to fault a bad install of the software or something like that.
    RAM, Drivers, and buggy software are the biggest causes of BSODs.
    Paste the BCCodes from the BSODs in here. Try to capture date from the BSODs or the event logs about which files are involved with these things from the error logs and the memory dumps.
    What is the section of the BSOD do you need to look at to determine what the problem is?
    OK I'll take a picture of the screen and post the code next time it happens - it seems it frequently happens at night after I've had my computer on all day.
Homebuilt iTunes Blue Screen Systems
