Sign-in / Sign-up
IS IT OK TO POWER MOBO WITHOUT CPU IN IT
  • New Build
  • Light
  • CPUs
  • Power
  • Systems
Last response: in Systems
December 30, 2011 7:28:27 PM
TRYING TO GET POWER TO SET UP LIGHTS, FANS ECT..
More about : power mobo cpu
December 30, 2011 7:29:57 PM
I'm not sure if the computer will even turn on without the CPU. Why do you want to leave out CPU?
m
l
December 30, 2011 7:33:35 PM
ITS NOT HERE YET STILL WAITING ON IT
m
l
December 30, 2011 7:38:11 PM
STILL WAITING ON CPU TO GET HERE
m
l
December 30, 2011 7:39:08 PM
Please do not use all caps. And to answer your question, no you cannot use your Mobo without a CPU.
m
l
December 30, 2011 9:30:16 PM
Sorry about the caps. Thanks for the info. You da man!
m
l
a b à CPUs
December 30, 2011 10:32:21 PM
Without the CPU, there is nothing to "process" the command of powering on the computer. Kind of like a human without a brain, or a heart, or vital organs.
m
l
December 31, 2011 1:22:27 PM
Thanks for the input. Im not wanting to process anything, what Im trying to do is get power to the case i have done this as a test with another computer, a junky one. What I did was set the junky pc next to my new one and ran the 24 pin power plug to it and ran everything else to the stuff in my new case, fan controller, lights, toggle switch bay, ect. The thing is the junker still has the cpu in it. Was just wondering if this same setup would work if the cpu wasnt in there or if it did work was it bad for the motherboard. Just trying to find a way to test the psu and other components without messing up the mobo. Does anybody know if there is a way to maybe bypass the mobo and still power the case, that way I dont have to have the junk pc wired to it and in the way. Thanks for the replys and I appreciate any help I get.
m
l
