I needed a budget 4 GB RAM compatible with the Intel Pentium G645, which only supports 1066 MHz memory. My chosen motherboard is dual-channel.
My first question is that can I use a single stick of 4 GB RAM in the dual channel, and if I can, is it way better to get a 2x2GB configuration? Price isn't a problem, the difference is marginal, but the one I was looking at, the Kingston Value RAM, is not available 2x2GB in India, where I live - although I can still ask someone to get it for me from the States.
Secondly, can you use the 1333 MHz modules with a 1066 MHz compatible processor, even if you only get 1066 MHz? Just wanted to know if they are compatible.
Thanks a lot
Thanks a lot
