Solved
Case Help
I was wondering what case I should get that has the following features:
-the ability to fit larger GPUs (also crossfire support of say a 7850)
-usb 3.0 ports
-good cooling
My budget is a hundred dollars and I am willing to go to a max of 120.
8 answers Last reply Best Answer
More about case help
    -usb 3.0 ports
    -good cooling
    No need to spend all that:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233
    or
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811119197
    These were designed for good cooling and large cards.
  2. I know those are great cases. But the problem is that they don't support usb 3.0, only 2.0. For my first build I want a case that isn't using older technology. Hopefully cm updates their haf series to support usb 3.0. But for now, they don't so I need case suggestions.
    They do in the rear. And if you're looking for front USB's:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811119160
    that'll cost you an extra $20.00 :)
  4. You know what I'll just start my build later on when manufactures update their cases. Because I don't want to exceed my budget. But thanks for the info.
  5. Best answer
    Sorry I couldn't be of more help.
    The mfg's probably won't update their cases until more devices that utilize 3.0 are available though.
  6. thanks i really appreciate as I'm only a first time builder. But considering a large portion of the new Z77 mobos feature usb 3, I think it will be before the year ends
  7. Best answer selected by naqib99.
    Fingers crossed!
Power Supplies Cases Support Crossfire Components Product
