Hi,
Recently i have upgraded my PC so here are the specs,
1) AMD FX6100
2) Gigabyte GA - 78LMT-USB3
3) Corsair Vengeance 1x8gb with heatsink
4) Seagate HDD 1TB
5) Intex 450w PS
I was able to install windows 7 and starting it was working like a charm and later on the next day i noticed that i am getting a blank display no beep sound and not even motherboard logo with PS is supplied
I tried removing the RAM and insert it again it was working fine as usual but lags if anything is loaded and mouse stops responding and if i shutdown the system i am facing the same problem again.
Everytime i can't keepon changing the RAM slots .
As my friends say that i should have bought 2x4GB instead of putting single stick 8GB memory. Do you think my RAM is not compatible with this mobo.
After investing so much on this i am not able to make use of it properly.
Please advice on this how do i proceed further.
Thanks,
Manju
1) AMD FX6100
4) Seagate HDD 1TB
5) Intex 450w PS
Thanks,
Manju
