If anyone could pleasssssse help me this is a super annoying problem. Ive searched the web for 6 hours trying to find a solution..
I removed every sound related driver/program from my pc to fix a sound error. I deleted everything out of program/features uninstall that had to do with audio.. I removed one called Audio(32) or audio Audio control panel.. cant remember the name. I have done every step ive found in 30+ threads. that include all of these and more.
I really dont want to have to reformat, any help would be super appreciated.
"note" all hardware is working fine. tested in other pc.
EVGA 750i FTW Windows 7 x64 ultimate SB Live 24bit!
~ Cannot Restore - there was no restore point made before the problem came
~ Reinstalled Driver - Manually downloaded driver from evga site. And also tried, uninstall then let windows automatically find and install driver.
~ Tried : Disable -> Enable Driver
~ Checked Driver Update
~ Checked Bios - all audio related options enabled
~ Checked Windows update
~ Speaker has been enabled, but i cannot Configure, Test, or Disable speakers and the levels tab is empty
~ Troubleshoot says "Audio Device has been disabled" and No Audio Output Device installed "even when all audio codecs and packages are installed and say working properly under device manager.
~ Tried Microsoft FixIt to no avail
~Both my SB live 24bit! and Realtek HD audio show up and running in audio manager say ready but cannot be configured
Nothing is working!! I need a real pro here!
