Aftermarket cooling for non-ref card
  • Graphics Cards
  • Cooling
  • Compatibility
  • Graphics
November 2, 2011 8:41:02 PM
anyone know of a aftermarket cooling that would work with HIS 6950 H695FN2G2M .
i was interested in the Twin Turbo Pro but not sure if it is compatible
More about : aftermarket cooling ref card
a c 214 U Graphics card
November 2, 2011 8:46:36 PM
Yes the twin turbo will work for the 6950.
It doesn't matter if the card is reference or non they all have the same chip placement which means any cooler that's meant for the 6950 will work.
Here's all the coolers from Arctic Cooling.Just match up which one is compatible.
http://www.arctic.ac/en/p/cooling/vga.html
m
l
November 2, 2011 9:14:30 PM
ok im gonna actually go with the twin turbo II
m
l
November 2, 2011 9:42:03 PM
I honestly don't see any difference between the twin turbo and the twin turbo II besides a different shroud and switched heatpipes.Since their's a $20 difference between the 2 I would suggest looking at some reviews to see how much of a difference there is temp wise.
m
l
