Solved
NZXT Tempest Elite 410 Changing Case Fans
  • Elite
  • Cases
  • Fan
  • Components
  • Product
Last response: in Components
April 10, 2012 11:12:21 PM
Hello, I recently purchased the Tempest Elite 410 (http://www.newegg.com/Product/Product.aspx?Item=N82E168...) and was simply wondering if I can replace to 2 front case fans and replace them with other 120mm fans. (specifically: Rosewill RFA-120-WL 120mm 4 White LEDs LED Case Fan) I was trying to remove the fan from it's current case thing that surrounds it, and was having a hard time doing so. I didn't wish to break it, so I thought I would ask some professionals before I put some more power into it. Below is a picture for reference of what I'm talking about:
I'm just curious if I'm able to unattached the fan at it's 3pin clip located in the picture.
Thank you for your time and help!
More about : nzxt tempest elite 410 changing case fans
Best solution
April 11, 2012 12:28:14 AM
Yes you can, no problems there.
April 18, 2012 12:09:41 AM
Best answer selected by KehrBehr.
m
l
