Does this ASRock Motherboard work with this Cooler Master Case?
keven0044714
8
I was wondering if this ASRock motherboard works with this Cooler Master Case?
Cooler Master Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233&nm_mc=AFC-C8Junction&cm_sp=&AID=10446076&PID=3938566&SID=
ASRock Motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813157331&nm_mc=AFC-C8Junction&cm_sp=&AID=10446076&PID=3938566&SID=
It's compatible, that's just optional, if you want the usb 3.0 ports in the front of the case or not, if you do, then change the case if you don't, you don't need to.
keven0044714
8
So do you think i should use this motherboard?
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130661&nm_mc=AFC-C8Junction&cm_sp=&AID=10446076&PID=3938566&SID=
