Asrock extreme 4 970 wont post
Hello,
just baught all new stuff to build my first brand new pc. ive built many pc in the past but never with brand new parts.
every thing should be connected right .
what happens if i hit power button on board or even power button on case is the motherboard turns on all fans all lights ect
the dr debug thing flashes a bunch of numbers but no matter what i do. once it gets to 0xcf the motherboard dies all fans still work but the leds on the motherboard power/reset/clear cmos turn off
here is the setup
ram 1x 4gb balistix 1600 (tryied different spots)
gpu gigabyte 1gb radeon hd6670
cpu amd fx 6300 6 core
psu 500 watt
my psu has 20 pin power plus another 4 pin to make 24 if need be
has 4 pin or 8 pin cpu power
also has 2 6 pin gpu plugs which i dont need.
everyb thing is brand new from microcenter besides the case and psu which came from my old working tower when i got this stuff.
3 answers Last reply
More about asrock extreme wont post
  1. Hi,
    It might be a BIOS version issue http://www.asrock.com/mb/AMD/970%20Extreme4/?cat=CPU .
    The 6300 requires P2.10. Check on the board for a sticker with the BIOS version.
  2. cant seem to find bios chip to tell which version u only
    i did read that orginal bios does not support my cpu which is dumb because they wre a bundle
    i have no other am3 cpu only a am2 is there any way to flash bios without cpu
    also read asrock has sent people with this problem new bios chips for free not sure how to do this ether
  3. If in US, you can try contacting Asrock http://www.asrock.com/support/index.asp?cat=RMA.
    If not, the BIOS chip is on socket and you can try replacing it: http://www.ebay.com/itm/BIOS-CHIP-ASROCK-970-EXTREME4-X79-EXTREME9-985GM-GS3-FX-Z68-PRO3-GEN3-/380542228204?pt=UK_Computing_Other_Computing_Networking&hash=item589a1596ec
    On ASUS boards the first three numbers of the board's serial stand for the fabrication date. It might be the same for ASRock.
    If the necessary BIOS version was issued before the board's fabrication date, then most probably the board has the right BIOS.
ASRock Power Motherboards
