Closed Solved
Are these parts compatible? And need advice on case.
Hi. I am almost ready to buy the parts for my new pc. I think they are all compatible but as I have not built a computer before I want to be sure that they’re all compatible. I also have not decided what case to buy yet and was hoping for some advice on that as well, my budget for a case is £40/$62 and my overall budget is £525/$814. I already have the RAM, HDD and Optical drive sorry I don’t have the links or exact names of HDD and Optical drive.
Motherboard: http://www.aria.co.uk/Products/Components/Motherboards/Intel+1155+Z68+%28B3%29/Gigabyte+GA-Z68XP-UD3+Intel+Z68+%28REV+B3%29+Socket+1155+DDR3+PCI-Express+Motherboard+?productId=45188
CPU: http://www.aria.co.uk/Products/Components/CPUs+%2F+Processors/Intel+Core+i5+%281155%29/Intel+Core+i5-2500K+3.30GHz+%28Sandybridge%29+Socket+LGA1155+Processor+-+Retail+?productId=43216
RAM: http://www.amazon.co.uk/dp/B0042A7CAA/?smid=A17AS5ETPMZ9A1&tag=idealocouk-mp-21&linkCode=asn&creative=6742&camp=1638&creativeASIN=B0042A7CAA
Power Supply: http://www.aria.co.uk/Products/Components/Power+Supplies/650W+or+less/650W+OCZ+ZS+Series+ATX2.2+80PLUS+Bronze+Power+Supply+?productId=45458
Graphics Card: http://www.aria.co.uk/Products/Components/Graphics+Cards/NVIDIA/NVIDIA+GTX+560ti/Asus+GeForce+GTX+560Ti+DCII%2F2DI%2F1GD5+DirectCU+II+1024MB+GDDR5+PCI-Express+Graphics+Card+?productId=43564
Please if you recommend a component could you recommend from a site that delivers to the UK. Thank You.
EDIT: I have cosen this Case: http://www.amazon.com/GAMMA-Classic-Interior-Chassis-Black/dp/B002UDK9U6
11 answers Last reply Best Answer
More about parts compatible advice case
  1. Here is a case I recently received:
    I have yet to get all the parts for the build, but the case feels rather sturdy.
  2. Best answer
    Should be fine.
    I would have went with different RAM, but if you already have it then I hope it works well.
  3. Looks good. I'd get the 560 Ti over the 560 though. The ~$40 US is worth it if you can fit it in your budget
  4. Raiddinn said:
    Should be fine.
    What RAM would you have gone with?
    Thanks for the advice, I changed the graphics card. Is it still compatible now i changed it?
  6. Yes should be fine
  7. This would be a better choice for your RAM.
    http://www.amazon.co.uk/Corsair-CML8GX3M2A1600C9-Vengeance-1600MHz-Memory/dp/tech-data/B00569K7LM/ref=de_a_smtd
    Your original choice is 1.65V and the one I linked is 1.5V.
  8. Graphics cards are pretty much universal.
    All you have to worry about is if you have too old of a processor and too new of a video card.
    A gtx 580 would probably bog down a Pentium 4 single core processor, for instance.
    As for what RAM I would have went for, I would have typed in "<motherboard name> crucial RAM" and went to the crucial.com link and hit show all compatible RAM, and then I would have chosen something off that list.
  9. This one is 7 GBP more and well worth it for the speed bumo
    http://www.aria.co.uk/Products/Components/Graphics+Cards/NVIDIA/NVIDIA+GTX+560ti/Asus+GeForce+GTX+560Ti+DCII+TOP%2F2DI%2F1GD5+DirectCU+II+1024MB+GDDR5+PCI-Express+Graphics+Card+w%2F+Deus+Ex+?productId=47110
    The 650 watter is good for one card .... but someday ya might wanna add 2nd so getting PSU to handle that now is advisable. But OCZ PSU's is not where I'd be looking. Jonnyguru performance ratings in ( )
    I'd suggest an 850 watt Corsair HX series (10.0) or TX V2 series (9.5) ... your site is pretty limited on choices. Antec SG / CP series also gets (10.0) ... HCG / HCP (9.5)....XFX Core (9.5).
  10. Best answer selected by Proximon.
  11. This topic has been closed by Proximon
New Build Cases Compatibility Systems
