Hi all.
For several days I have been experiencing a verry annoying problem where without knowing what part i should blame, PSU or MB. The problem is that one morning when I turned on my pc I got the asus power surge and cpu overvoltage problem where in the bios I was supprised by the following readings.
Vcore- Reading 1.9v
3V- Reading 5V
5V- Reading 10+V
12V- Reading 24+V
First I tought that if it really was the problem my pc wouldnt power on.(I was still able to play all the games(planetside2 for ex) and everything was cool.
I downgraded the bios and everything went back to normal except for the 12V rail still reading 14-16 volts.
Also checked the PSU voltages on the 24pin and all seamed ok.
I ran a torture test with prime 95 and averything was cool as well.
Could it be a buggy bios (uefi)?
Would buying a new bios chip solve the problem?
Im almost sure its the board problem since my cpu temp is also reading negative 60degrees all the time.
But if it is a software problem I heard that asus will not RMA.
Im at a point where i dont know what to do so any help would be appreciated.
If you need to know my specs are:
i7 2600k @3.6GHz
ASUS P8P67 Pro Rev3.1 ------->Latest uefi
16GB vengeance ram
120 Gb ssd + 2other
Asus radeon hd 6950 2gb
Cooler master silenzio 700w
Thank you.
Vcore- Reading 1.9v
3V- Reading 5V
5V- Reading 10+V
12V- Reading 24+V
i7 2600k @3.6GHz
16GB vengeance ram
120 Gb ssd + 2other
Thank you.
