In general, the HX series from Corsair is excellent....the 1000/1050 is a notable exception where they garner only 8.0 / 8.5 performance ratings. I'd move to the AX1200 which gets 10.0 rating.
http://www.jonnyguru.com/modules.php?name=NDReviews&op=...
Consider the Corsair 500R, Antec 1200 V3, Antec DF-85 or HAF-X
I don't think much of the H series coolers.....lotta noise for no significant gain, most H series can't match air cooler performance. Thermalright Silver Arrow or Hyper 612 PWM would be my recommendation.
Drop the toothy heat sinks....they don't do anything....and no need for more than 8GB .... but it is cheap so why not.
The 2600k's hyperthreading isn't helping you in gaming, 2500k saves $80 and only loses 0.1 Ghz .... then again there's also the 2700k
The M4 is tier 5, why not tier 3 ?
http://www.tomshardware.com/reviews/buy-ssd-recommendat...
No need for a sound card
Consider Windows professional....Ultimate just gives ya Bit Locker.
As for the MoBo, yes Z68 has other features that P67 doesn't have, but do you need any of them ? I think not:
http://www.ukgamingcomputers.co.uk/difference-between-h...
Quote:
Z68
Launched 5 months after the P67 and H67 chipset the Z68 chipset combines the advantages of the H67 and P67 Chipset so that overclocking, dual dedicated graphics cards and use of the integrated CPU graphics is available.
Whilst on the surface it would seem that this would be the chipset to go for, how many users that have 2 dedicated graphics cards will actually want to use the onboard graphics when they already have 2 more powerful graphics cards in their system anyway?
The only real advantage is for users that wish to access the HD graphics features such as quick sync, but considering it’s only supported by very few transcoding programs and there are not many people out there that need or will want to transcode,
it makes it almost pointless to choose Z68 over a P67 chipset.
Same applies to users that want to overclock the CPU but use the onboard graphics card; it’s a very limited market.
Finally, another feature of a Z68 chipset is known as SSD caching which is where it allows the use of a small (say 10 or 20 GB) Solid state hard drive to act as a cache for a larger ‘traditional’ hard disk.
If you are already planning the use of a Solid State drive this feature is redundant.
If you can’t afford a decent size SSD (40GB+) then there are more cost effective ways around using a small SSD and SSD cashing like spending less on a motherboard, (H67 chipset or even a P67 chipset) and putting the saved money into a decent size SSD.
Unless you just wanna have "the latest and ...." well ya read the above .... there's no reason to completely disregard P67....especially with twin 580's. The NF200 chip in the WS Revolution for example gives your 580's x16 x16 GFX as opposed to x8 x8 on just about everything else. On anything below a 560, there's no discernable impact and when there is it' s usually small but it can be as high as 10% in games like STALKER. And lets not forget, you just paid about $680 to get 10% using those 580s over 560 Ti's .... this 10% comes a lot cheaper
....though it's more likely to be 2-5% in most games.
Here's a review
http://www.tweaktown.com/reviews/3795/asus_p8p67_ws_rev...
$425 / $525 for the MoBo and 2500k / 2600k here
http://www.newegg.com/Product/ComboDealDetails.aspx?Ite...
The HD is smokin.....gives SSD 's a run for their money .......The Vertex 3 Max IOPS boots the box upstairs 1n 15.6 seconds .... the Barracuda XT in just 21.2 seconds.
http://benchmarkreviews.com/index.php?option=com_conten...
GFX - Be aware that the twin 580's at $1000 get just 10% more fps (953) than twin 900 Mhz 580s (862) for $460 .... if ya need to economize, that's where's I'd start. And no, the 590 is a dog.
As to the new gen cards, I pay no attention otherwise I get case of buyer's remorse....these introductions mean a couple of things .....
1. High prices for the new thing
2. Lower prices for what just became passe
3. Revision A hardware headaches. I'm more of a Revision C guy when all the fabrication bugaboos are worked out, the defective parts of the design are weeded out, drivers are matured and, most importantly, the non-reference tweaked designs are out....that's gonna happen in late spring. The best example of this are the B1 version of the P67 MoBos with the bum SATA ports, but the GFX industry has had its share of the same.
