Hi there,
I recently bought this card and after playing a few games and monitoring temps and voltages etc. I noticed the fan speeds never exceeded 41%, even when the card is under heavy load and reaching temperatures of 58 degrees celsius. Has anybody else had a similar problem with this card or heard of anything similar? I know that Asus advertise that the DirectCU cooling means the card should not have heating issues but obviously this should not mean the fan speeds are limited in any way. I'd really like to get this sorted out and hopefully get the card running a little cooler under load so any help would be much appreciated. My specs are as follows:
i5 2500k @ 4.6GHz - Cooled by a Corsair A50
Asus P8Z68-V pro
Kingston HyperX Genesis Grey 8GB - PC12800
Asus GTX 560ti DirectCU 2 TOP
Cooler Master Silent Pro 700W Modular
640GB Samsung Spinpoint
Asus Sonar DS
Generic Opitcal drive
Thermaltake Armor Jr. Case with 2 X 120mm Cooler Master Fans for cooling
My CPU temperatures are fantastic, it never breaks 40 degrees celsius so I'm not so sure why my graphics card is getting so hot.
I can give screen shots from CPU-Z and GPU-Z if needed, might give you a clearer indication of how the speeds are rising with the temperatures.
Also if anyone could recommend any good software for tweaking and monitoring fan speeds,t hat would be great. I have used; MSI - afterburner, EVGA precision tool and Rivatuner in the past but I always feel they're a bit lacking. I'm (stupidly) waiting on the GPU tweak software from Asus to become compatible with my card but they have a habit of not meeting expectations with their software.
Thanks,
Bam
TL,DR; Fan speeds never break 41% with this card.
Asus P8Z68-V pro
Asus Sonar DS
Thanks,
Bam
