Motherboard isnt making any noise
Vegetto991
20
my motherboard used to make a beep when turning on I believe that is called posting, I installed a new graphics card had to remove alot of wires around to fit the card and now it wont beep, but it still turns on and I can access bios and everything works fine.
motherboard is a p8z77-v lk
wiggbot
343
You've probably dislodged your pc speaker. I wouldn't worry about it. In the case you'd like to fix it, refer to the manual of your motherboard and find where the pc speaker pins are. See if the speaker has come loose.
