PLease can people comment on this system. trying to build a PC
Hello,
here are my components. Please can people tell me if it will work and if its any good. I want it mainly for music and Video but also to play starcraft 2.
Novatech Aura Micro-ATX Case - No PSU
Novatech GeForce GTX 460 1024MB GDDR5 PCIe
OCZ Agility 3 SATA III 2.5" 60GB Solid State Hard Drive
Novatech Motherboard Bundle - Intel Core i5 2400 - 4GB DDR3 1333Mhz - Intel H67 Motherboard
LiteOn IHAS124-19 24x DVD+/-RW SATA Black - OEM
Novatech PowerStation Gaming 600W Silent ATX2 Modular Power Supply
I have never built one before so please tell me if I have missed something. I have mouse and key board and speakers. I do want to link it with my tv aswell so any advice would be great.
cheers
4 answers Last reply
More about please people comment system build
  1. First, you'll need an operating system. Since it's for gaming, you'll probably want Windows 7 Home Premium:
    http://www.microsoft.com/windows/buy/default.aspx
    I would also not buy the SSD and instead buy a better CPU/motherboard/gpu. Something like this:
    CPU: Intel core i5 2500k
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
    Mobo: ASRock Z68 Extreme3
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813157271
    GPU: Radeon 6870 or gtx 560Ti (depending on which you can afford)
    6870: http://www.newegg.com/Product/Product.aspx?Item=N82E16814102948
    560Ti: http://www.newegg.com/Product/Product.aspx?Item=N82E16814125401
  2. ok thanks. what kind of Hard drive do you think I need? want about 500 to 1tb i guess.
    and is the power supply enough?
    thanks
  3. ok thanks. what kind of Hard drive do you think I need? want about 500 to 1tb i guess.
    thanks
  4. 1. I would get a 250GB HDD for now, since prices are so high up due to the flood. If you can get another $30, you can probably get a 500GB Seagate drive (go to your nearest BestBuy and ask for their Hard Drive section). This works if you don't have a BestBuy near your house:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822148767
    2. For the powersupply, if it actually outputs 600W, it should be good even for SLI/CF, however, I've never heard of Novatech before so I really don't trust them. Go with a trusted company such as Seasonic or FSP. (Some Corsair, Antec, and OCZ PSUs work too, but not all are reliable)
New Build Novatech Systems Product
